IF-RIO
5641R Documentation for the Input ports
I'm looking for documentation for the inputs for analog inputs and what they do.
These include: "ADC_0_Port_A_RSSI" I know it's a power measurment of something, but when does it get updated? What is the exact output of this?
Thank you
(5,550 Views)
Hi d1sturbanc3,
I believe for the level of detail you are asking for your best option will be to refer to the AD6654 data sheet found here.Timing diagrams are included which should provide an answer to your questions.
http://www.analog.com/static/imported-files/data_sheets/AD6654.pdf
JaceD
Signal Sources Product Support Engineer
(5,544 Views)
