IF-RIO
Are IRQs supported for IFRIO
Do users have access to IRQs for the IFRIO target ? If so, is there a subset of logical IRQ#s that should be used, or any configuration needed apriori ?
I get an error (code: 61053; Resource port MiteIrq0 must be defined before used by component rvi_Instance_21_21MyFPGAVi).
Thanks.
(6,176 Views)
Hi manikg
Unfortunately, the NI PCI-5640R does not support use of IRQs with the FPGA target.
Jerry
(6,170 Views)
