IF-RIO
Can I access 8.6 VIs in 8.5 (ex. FFT Block)?
We have not received an updated copy of labView to 8.6 yet, but I need some of the blocks from 8.6 for my application.  Is it possible to get access to any of the blocks for 8.6, specifically the FPGA FFT block?
Patrick
(6,622 Views)
The following link might be useful
http://decibel.ni.com/content/docs/DOC-1052\
--Vinay
(6,614 Views)
Vinay,
I am trying to use the FFT block with an NI-5640R board.  The FPGA VI does not have any errors but when I start to compile, I get Xilinx compile errors:
 ERROR:HDLParsers:3312 - "C:/NIFPGA85/srvrTmp/LOCALH~1/NIF6AB~1/case_12aaf5bc_frame1_11cefb38.vhd" Line 692. Undefined symbol 'UNDRIVEN_INPUT'.
ERROR:HDLParsers:1209 - "C:/NIFPGA85/srvrTmp/LOCALH~1/NIF6AB~1/case_12aaf5bc_frame1_11cefb38.vhd" Line 692. UNDRIVEN_INPUT: Undefined symbol (last report in this block)
ERROR:HDLParsers:851 - "C:/NIFPGA85/srvrTmp/LOCALH~1/NIF6AB~1/case_12aaf5bc_frame1_11cefb38.vhd" Line 685. Formal t11ce20fc of commentNode_h15bac1c0_n12aa361c_11cef4a8 with no default value must be associated with an actual value.
Total memory usage is 249924 kilobytes
Number of errors   :    3 (   0 filtered)
Number of warnings :    1 (   0 filtered)
Number of infos    :    0 (   0 filtered)
ERROR:Xflow - Program xst returned error code 6. Aborting flow execution...
Bitstream Not Created
Timing Analysis Passed
I have attached the FPGA VI  screen shot of where I implement the FFT code.  I would like the FFT to run continuously and constantly send the FFT data back to the Host.
Patrick
(6,595 Views)
Sorry, that was the wrong file. Here is the correct FPGA VI image.
Patrick
(6,593 Views)
Patrick,
Can you please zip the project and send it to me? Its difficult to know why the error is occuring just from the snap shot.
Also, can you please post the same question to the owner of the FFT block on the same page from where you downloaded it?
--Vinay
(6,577 Views)
edit: sorry, wrong answer - I've misread the numbers of the total memory usage message.
____
Hello Patrick,
your compiler crashes because of this:
It's the 2G-limit of your 32bit-OS. I had the same problem for a while until I read that there is an optionto increase available RAM for programs.
For XP searchwords (for eg google) are:  boot.ini /3gb
For Vista: /increaseuserva bcdedit
After that your program should compile.
Greets,
Lars
Message Edited by Lars.B on 12-01-2008 03:14 AM
(6,554 Views)
