IF-RIO
Can PCI-5640 be controlled using Labview 7.1?
I am running Labview 7.1 and acquired a PCI-5640. I installed the 5640 drivers (ver. 1.1) but cannot find any 5640 VI's  in Labview.  Is Labview 8.2 required to control the 5640? Thanks.
(5,939 Views)
You will get all the new features for the board in LabVIEW 8.2. It can also be run with LabVIEW 8.0 but the feature list is reduced. It cannot, however, be used with LabVIEW 7.1 or previous versions.
(5,932 Views)
