IF-RIO
Compilation Summary
After completion of a successful synthesis, we can view the clock rates in the Compilation Summary dialog box. However, sometimes this dialog box does not show up - this happenned when we had disconnected the Client during compilation.
Can the clock rate information be accessed elsewhere ?
-M
(6,280 Views)
Make sure the "Show Compile Summary" box is checked in the Tools>>FPGA Module Options dialog.  This box must be checked in order to see the summary.  If this box isn't displayed you can also find the information in the build.rpt file.  The build.rpt file is located in the c:\NIFPGA80\clntTmp folder for each design you compile.
Joseph D.
(6,273 Views)
