IF-RIO
Error FFFFFFFE: FPGA Signature doesn't match
I am using 5640R. When I tried to run the "ni5640R Analog Input" example, the first time would be okay, but the next time will fail with an error FFFFFFFE. The source is "private_5640_signature Register Verify.vi" and the message is "FPGA Signature doesn't match". What can I do to eliminate this error?
Thanks very much!
Best Regards,
Tim Kuo
(6,194 Views)
hello Sir,
I want to Generate the Single Side bands (LSB,USB). I got the Am Modulation output but failed in to get side bands.
I am using PCI 5640R card, i have to check these signals on external oscillsocope.
please guide me to get these signals.
Thanks.
(5,706 Views)
