IF-RIO
Is there a way to reset the DAC outside of LabVIEW?
I was running the example VI 'NI5640R Single Tone Output' and discovered that the VI does not close out the DAC after the program has finished running, i.e. the output channel continues to output a waveform.  Is there an option in MAX that will reset the card?
(6,378 Views)
There is no way to reset the DAC outside labVIEW. However, if you want, then you can put a VI named "DAR Reset" as the last VI of that example and that should take care of it.
(6,367 Views)
