IF-RIO
Multiple issues with PCI-5640R FPGA: DAC and Strange Execution at Host
We are working on a communications systems project using the PCI-5640R IF-RIO transceiver and the FPGA module. At the FPGA, a sequence of bits are being modulated through multiplication with the sine wave generator.  The next step is to take the modulated sinusoidal signal and send it through the DAC. Throughout this project, we have been using the Analog Input and Output example project from Getting Started with the 5640-R IF... as a template to build this project.  There are, however, several issues/questions we have.  Attached are the HOST and FPGA vis that we are working with.
1.  The host only runs every other time.  At the host (BPSK_TX(HOST).VI, the execution gets halted for an infinite period of time at one of the FIFOs until 'stop' is hit.  But then at the subsequent execution, the host completes execution of the program.  In other words, the host is only receiving data from the FPGA every second time it is run. Why is this happening?  Are we missing something at the host or FPGA VI?
 2.  How exactly do we send our own digitized signal through the DAC?  As seen in one of the FPGA VIs, we have tried modfiying the output section of the FPGA VI in the Analog Input and Output project in which the FPGA reads from the FIFO.  In our case, we are modulating the signal in a separate section, writing it to a target-scoped FIFO and then reading from that FIFO and processing the data as in the example.  This modified FPGA vi is "BPSK_TX(FPGA).VI)
Unfotunately, we are not observing anything at an oscilloscope connected to the transceiver.  Even when we try to pass in a "custom" signal at the HOST we have no luck observing anything coherent.   As seen in the bare_sine_wave_test (FPGA).vi, we have attempted a relatively simple way of sending a signal through the DAC, yet still no luck.  I am guessing that this is related to issue #1.
On a related note, when receiving the signal and running it through the ADC, what steps are necessary?  Can one assume that it is similar to the FPGA.VI in the analog input and output example?
3.  How do for loops and while loops synchronize with timed loops and frames in the FPGA?  In the FPGA we are using a for loop to modulate the signal because the sine wave generator cannot be contained within a timed loop on the FPGA.  This will be important to us because at the receiver we will need to know the symbol rate in order to recover the signal.
 I would sincerely appreciate any feedback or help that can be provided on this,
Message 1 of 1
(6,127 Views)
