IF-RIO
Port A Error
I got the following error message during the compile:
Regenerating IP...
ERROR:coreutil - Failure to set parameters on core: Illegal combination: Port A
   Width and Port A Depth
ERROR:coreutil - Failure to generate output products
I don't know what does this 'Port A' mean and how to fix it.
I am using LV 8.20 and IF RIO 1.0.  I installed by following steps:
1. Copy C:\Program Files\National Instruments\LabVIEW 8.0\instr.lib\ni5640R
   to   C:\Program Files\National Instruments\LabVIEW 8.2\instr.lib\ni5640R
2. Copy C:\Program Files\National Instruments\LabVIEW 8.0\Targets\NI\FPGA\PCI-5640R
   to   C:\Program Files\National Instruments\LabVIEW 8.2\Targets\NI\FPGA\PCI-5640R
3. Copy C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\LabVIEW Targets\FPGA\PCI-5640R
   to   C:\Program Files\National Instruments\LabVIEW 8.2\vi.lib\LabVIEW Targets\FPGA\PCI-5640R
4. Copy C:\Program Files\National Instruments\LabVIEW 8.0\examples\FPGA\NI-5640R
   to   C:\Program Files\National Instruments\LabVIEW 8.2\examples\FPGA\NI-5640R
5. Run  C:\Program Files\National Instruments\LabVIEW 8.2\Targets\NI\FPGA\bin\lvfpga_make_resource_cache.exe
(7,178 Views)
I found the reason, but very strange.  It is due to an I32 memory with depth=1.
When I set target as 5640R, I creat a I32 memory with depth=1.  Read the address 0 in an infinit loop.  Compile it.  You get the Port A error.
When I set the depth =2 or =6, it is OK.
It happens to I16 and U32 too.  But it is OK with boolean.
Hope I catch a bug.
(7,164 Views)
Hi Ex-NISH2
It sort of is a bug indirectly.  The Xilinx tools do not support a depth of 1, so we need to remove it from the capability from the dialog or put in code that replaces the memory block with a register in this case.
The only work around at this point is use some other "register" to hold the value such as locals, globals, fifos, feedback nodes, etc...
Jerry
(7,159 Views)
I am passing start stop through VIs with memories.  It can work with SCTL and different clock domain.  Can Global do the same thing?
BTW, boolean memory can not set depth=1 either.
(7,153 Views)
Hi Folks,
I'm resurrecting this thread because I just saw this anomaly crop up in NI FPGA 8.5, and it was pretty cryptic to track down.  I increased the depth of the memory and the problem went away.  To make this information easier to find for others, here's the full text of the error message that appears:
ERROR:coreutil - An error occurred while running Java. Please examine the
   console or coregen log file for a specific IP related error.
   If there is no specific error the problem may be due to memory limitations.
   For more information please consult solution record 21955 available from:
   http://www.xilinx.com/xlnx/xil_ans_display.jsp?getPagePath=21955Finished Regenerating.
ERROR:sim:57 - Error found during generation
May I humbly suggest the following?:
1.    Is there a way to change the NI FPGA implementation of the memory allocation such that a depth of 1 doesn't cause any issue?  (Even by allocating a depth of 2 behind the scenes with a dummy element)
2.    Would it make sense to only permit users to enter 2 or more in the depth field on the Memory Properties dialog, possibly with an explanation?
Thanks in advance,
Jim
(6,783 Views)
