IF-RIO
Questions on IFRIO
Hi All,
I have some questions on IFRIO. Would really appreciate any help.
1. What is the least power that can be measured by the 5640R (dBm)?
2. In how much time a frequency sweep of 50 Khz frequency centered 5 Mhz be done with minimal change in frequency steps?
3. If I provide an external clock of higher stability (better than 25ppm) will this make the 5640R more stable?
4. What does the spec "tuning time" mean (tuning time = 1ms) ?
Thank you.
Message 1 of 1
(6,141 Views)
