IF-RIO
Real Time repeater using NI PXie 5641
Hello
Tankyou the suggestions have really helped me, I think I am almost done, but now I have a small problem, How can I clear the DRAM buffer (at runtime)?? I am using a CLIP implementation
Message 11 of 12
(3,537 Views)
Well, there are probably multiple ways of doing it, but the first thing that comes to mind for me is using the Data_Available signal.  If you are using the FIFO CLIP then there should be a line called "Data_Available" which is true when the following conditions are BOTH TRUE:
A) There is data in the FIFO
B) The internal circuitry of the device is ready for you to read the next FIFO element.
So, what I would do is:
1) Stop putting data into the FIFO
2) Start checking the Data_Available line, and while it is true, do a read from DRAM, but throw away the data.
3) I believe that the DRAM is at a speed such that if you are running your DRAM loops (in LabVIEW FPGA) at 40MHz, then condition B above should never be an issue. That would mean that as soon as Data_Available goes false, your buffer should be clear.
HOWEVER.... I think the safest way to ensure that the FIFO is done clearing is to check Data_Available on a few consecutive cycles of your Single Cycle Timed Loop and make sure that they are all falses. If you see Data_Available=false on 3 or 4 iterations of the 40MHz clock in a row, then I think you can be pretty certain the buffer is clear.
Hope that helps.
Message 12 of 12
(3,535 Views)
