IF-RIO
Run error while loading FPGA host vi
I want to use the NI-5640R board and have LV-FPGA installed together with LV 8.2...I have followed the post at :
and have taken in the newer drivers etc and the msg thread at  :
and copied the files from the LV 8.0 area...
Now, when I open up an existing example project (Single Tone Output), open up the Host Block diagram, I see the run button broken with some errors on the Thernal Shutdown subVi...
A software component for your target was not found. Make sure all target files are installed from the target installation CD. Error details:
Error 1059 occurred at New VI Object in StockFPGA_IntfScriptSubVI.vi:4->StockFPGA_ScriptMethod_Reset.vi:1->nirviCallScriptMethPlugin.vi->nirviMethod.xnode:nirviMethod_GenerateCode.vi:1->nirviMethod.xnode:nirviMethod_GenerateCode.vi.ProxyCaller
Possible reason(s):
LabVIEW:  Unexpected file type.
I understand that the installation might not be correct ? Any clues on what is missing...
-thanks
anshuman
(8,276 Views)
We met the same problme with another computer installed with another 5640R. Any clues?
Message Edited by david uang on 04-07-2007 05:19 PM
(8,008 Views)
Hi
Did you do the last step?:
2. Run  ...\LabVIEW 8.2\Targets\NI\FPGA\bin\lvfpga_make_resource_cache.exe
On this page?:
http://forums.ni.com/ni/board/message?board.id=ifrio&message.id=131
Jerry
(7,988 Views)
