IF-RIO
Running FPGA VI in Emulation Mode in Labview 2009
    How I can run FPGA VI in Emulation mode in Labview 2009 so that I can run FPGA VI before compiling it?
Thanks and Regards,
Rashid
(6,454 Views)
Accepted by topic author Rashid931
Hello Rashid,
Do you have an 5640R or another R-Series based board? I am going to assume your FPGA VI makes hardware calls to a 5640R because of the forum in which you have posted. If this is the case, due to the architecture of the template Vis, emulation mode is not supported in NI-5640R. If you wish to emulate your logic and no hardware calls this is possible but this can also be done in a host vi.
Message Edited by ColeTrain on 06-01-2010 11:52 AM
ColeR
Field Engineer
(6,446 Views)
Thanks ColeTrain.
Yes I am using NI PCI-5640R and my FPGA VI makes hardware calls to PCI-5640R.
Rashid
(6,435 Views)
