IF-RIO
address
HI ,
      I am trying to run the example code
C:\Program Files\National Instruments\LabVIEW 8.0\examples\FPGA\NI-5640R\ni5640R IQ Output
ni5640R IQ Output ---> this program asks for microport address as its input where can i find this(i am trying to run only the fpga vi)
can u pleasse help me..... initially i got a good help from u ppl..... i know i am asking too many doubts till now i have posted lots but nowadays i dont get help
can anyone pls help me????
Thank you
Valli
(8,997 Views)
HI Valli
The microport address is configured in the Host VI.  You should not have to worry about setting it directly.  Although you could figure it out by looking at the Host VI.
Which brings up the next point.  I assume you are trying to run the FPGA program directly.  You should not be doing this.  This is not the proper method of using the NI PCI-5640R.  You should be running the Host VI.
On the contrary, I believe I have been bending over backwards trying to help you, including posting from home in the evenings.  But I need you to get up and running on the released version of the code.  We do not support the Beta software any longer.  At least I believe you are using the beta software based on your past posts.  That is why I need you to reinstall the ni5640r software with the released version.  With confirmation that you downloaded it and did as I asked in my last post.  As I stated before, it is not worth trying to get you running from where you are now until you reinstall with the confirmed released software.    Previous post (and directions): http://forums.ni.com/ni/board/message?board.id=ifrio&message.id=168&page=3
Jerry
(8,993 Views)
hey jerry,
            please dont mistake me ...... i know u do reply the same minute for every msg i post
but suddenely i missed track of the replies that i get from u coz my gmail had blocked the reminder mail wen u post for me.....
i jus got to see all ur posts for me....... am so sorry jerry
i will surely reinstall that version...... thanx soo much jerry
Take care
Valli
(8,987 Views)
hey jerry,
              my installation step was
1.NI RIO 2.1
2.NI 5640R
3.LABVIEW 8.0
4.LABVIEW FPGA MODULE
When i try to install the labview fpga module it asks for nirio cd..... what should i do.....???? i have nirio2.1 in a folder that i saved from the ni link
when i try to add that folder *.exe file it says the "the required file not found"
(8,968 Views)
Valli
If you are reinstalling everything, the installation steps should be:
1. LabVIEW 8.0
2. LabVIEW FPGA MODULE
3.NI-RIO 2.1
4.NI 5640R software
It is always a good idea to install your application development environment (ADE) prior to installing drivers/add on software.  This is so the drivers can place the required components in the LabVIEW directory.  If LabVIEW isn’t there, some of our drivers do not install their respective components since they can’t be used.
You should be able to just cancel the part asking for the NI-RIO CD.  Actually, when you configure the installation, you select that that specific component not be installed.  This is part of the installation configuration.
Sorry, I think you may have to uninstall and reinstall again.  But that does not include LabVIEW.  If you uninstalled LabVIEW FPGA, there might be an issue there now. So, now I recommend uninstalling LabVIEW FPGA and then reinstalling.  Remember, configure the configuration page so the NI-RIO is not installed.  When the LabVIEW FPGA is installed, then install NI-RIO from the files you downloaded.
Jerry
(8,966 Views)
hi jerry,
              i did all the steps as u instructed.... my labview and fpga is perfect like the window that u showed me
i have sent a zip file with this post.....
zip 1 --> is the window that we were expected to get and i got it too
zip 2 --> can u see the difference in the FPGA target place;..... because of that after simulation the system says that "no fpga target to download the program"
my zip 1 target space should look like the one in zip 2 ........(RI0: INTR...) is missing
i tried to create a similar fpga vi but it says that it is missing sub vi file for obvious reasons( no lib file) so wat am i expected to do jerry
thank you
Valli
(8,876 Views)
hi ,
    i was able to fix the previous error of mine..... i am now stuck with  HEX error.... i am trying to simulate the example i
ni5640R IQ output example. Can you please help me???? I know you are kinda busy.... can you please help me.... coz its high time for me research please
Thank you
Valli
(8,846 Views)
