IF-RIO
host vi crashes host computer
I have  design that I have been running in simulation.  When I switched to run on the target the host VI crashes the host computer.  The host vi reads inputs from 2 files and writes outputs to 2 different files.  So far I have tried doubling the size of the FIFOs as well as adding the FIFO.start method for each FIFO.    I have also tried configuring the depth of each FIFO in the host vi. The host vi is attached for clarity.
Message 1 of 1
(6,516 Views)
