Indian LabVIEW Users Group (IndLUG)
LabVIEW 2015 FPGA Compile Worker Cannot Perform the Compilation
Hi Members
Recently I have installed PXIe-7822R FPGA target in my PXI system.
Currently i am having Licensed LabVIEW 2015 (32bit) version and it is installed Windows 7.
i verified Compatibility between Xilinx Compilation Tools and NI FPGA Hardware
I have installed 2015 version FPGA  Module, Vivado 2014.4 and ISE 14.7 inorder to communicate above mentioned FPGA Target.
after creating Simple FPGA VI (Only one DO Control write function), while trying to run FPGA to create bitx file through compilation in the local server, the following error displayed in the compilation window.
Many times i repaired and reinstalled the FPGA module and compiler tools, the error still persists.
kindly do the needful and helme out to sort out issue
Message 1 of 1
(2,666 Views)
