Indian LabVIEW Users Group (IndLUG)
LabView Azure Active Directory Access vi
I am using LabView 2016. I want to build a LabView application to authenticate using Microsoft identity platform and Azure active directory. The client application needs to request an Azure AD access token by using the following parameters:
1. Azure AD tenant endpoint.
2. Resource URI
3. Application Client ID
4. Application redirect URI.
In .NET equivalent, it uses method like AuthenticationContext.AcquireTokenAsync(String, String, Uri, IPlatformParameters)
I am not able to find any relevant example in LabView to do this. Although NI Cloud Toolkit for Azure is available, but it does not provide such similar examples. If someone on this forum have done similar vis, then please help!
Message 1 of 1
(3,284 Views)
