Industrial Communications
9144 Chassis IO EtherCAT State numerical values for different states
9144 Chassis offers among others, the "EtherCAT State" signal, which is available as 8-bit UINT number.
What is the relationship between this number and EtherCAT states (init, pre-op, safe-op, operational and bootstrap)?
Or if it has some other meaning, what's the meaning?
Jerry Kowal
(5,371 Views)
Below attached the map.
Note:usually, using LabVIEW, one should get/set the slave state by Programmatic API node without knowing the number.
(5,363 Views)
Zhou,
That's what I've been looking for.
I could not find this information anywhere and at the moment I don't have an access to the hardware so I could not check it myself. .
My plan is to monitor the EtherCat state on the FPGA and manage hardware outputs based on it.
Yarek
(5,355 Views)
