Industrial Communications
Bosch Rexroth HCS01 - active mode
I'm working with CRIO and Bosch RexRoth HCS01 motor.
I can't set in active mode the system by SDI Bosch Rexroth library (I attach the vi) and the communication is in PreOperational state.
If I right click mouse on CRIO icon of project, then Utilities, then Scan Engine Mode and then Switch to Active works fine.
Can you help me?
thank you
(3,040 Views)
Hey Simone,
This sounds correct. The Scan Engine needs to be active to deploy the EtherCAT variables. Here is a Help page that talks about the relationship between Scan Engine states and EtherCAT states.
Andrew T.
"His job is to shed light, and not to master" - Robert Hunter
(2,989 Views)
