Industrial Communications
Communication between IEC 60870-5-104 protocol and OPC server
Hi
I am using IEC 60870 toolkit in labview and trying to make one station as a master and other station as slave.
But recently I came to know that with reference to IEC 60870, Master can not be created in Labview.
Hence an OPC server has to be used to communicate between two stations in Labview where the two station
will be acting as slave and OPC server as master.
So i have used a third party OPC server "Cybserver 870-5-104" as a Master and made two vi's acting as client
one vi is used to send the data and other is to receive the data from the OPC server.
But communication is not getting established between the OPC server and Labview vis.
Can some buddy tell,Is that a right approach??
If not than pls suggest the wayout .
Regard
Gaurav
(7,997 Views)
Hi Gaurav,
Was this question escalated to me internally also? If so we will continue it there, if not I will post back to this forum with what we find on that issue. At the moment we haven't gotten this configuration working.
Jesse Dennis
Engineer
INTP
(7,950 Views)
