Industrial Communications
Comsoft Profibus Commnucation CPU315-2 DP
I buy a Comsoft Profibus Card, I connect with Siemens S7300 CPU315-2 DP Module.
Below is my configuration in Comsoft Configurator II Window.
The attachements is my PLC side configuration.
You can see from the image above, it is red frame.
Red frame
Slave is not communicating
So what the problem is?
The error comes from PLC side or PCI side, or even the cable side?
Thank you for your advise.
http://www.vitst.com
Virry Test & Control
LabVIEW Certified Developer
(6,849 Views)
Try double click the slave to see what the diagnostic says.
DirkW
(6,612 Views)
