Industrial Communications
Confusion between different protocols
Hi everyone,
I am a controls engineer at Satyam Mechatronics Pvt Ltd, I am in charge of designing the control system for packaging machine.
We use B&R products in the control panel so the part is very clear that we have to use B&R's Powerlink as a communication protocol.
But, when it comes to designing network involving robots and servos of different makes, I get really confused as to which protocol should I use.
Most preferably, I use Ethernet/IP for communication between PLC and Robots and EtherCAT when I want to make a machine which involves individual servo axes and motion control.
Can you suggest me whether my selections are right or wrong and how are other alternatives better in different cases?
(2,066 Views)
if you are using B&R for motion control, powerlink would be specifically for the application, for communication with the other devices in my experience it will depend on the customer specification, but usually they use more ethernet/ip.
best regards
(1,639 Views)
