Industrial Communications
Connecting LabVIEW to Schneider Electric M258 Logic Controller (TM258LF42DT4L) Error - 1967353901
I eventually established communication via modbus ethernet using an alternate IP address for the PLC, which was assigned by my laptop. The CPU utilizing its serial port won't assign it an IP address unfortunately. Now, I need to scan the logic controller and populate a library with all of the control points to read from and write to. How do I go about this? I'm trying to find the logic controller software and install it on my laptop.
Sam
Message 11 of 12
(3,237 Views)
Accepted by topic author saraqu02
That also sounds like something that the PLC manufacturer should be able to help you with. From our end, all that matters is that you're able to connect.
Tanner B.
Systems R&D Engineer - Aerospace, Defense, and Government
Message 12 of 12
(3,213 Views)
