10-28-2014 07:39 PM
I am looking to connect a PCI-8532-equipped PC to some already existing processing equipment running on DeviceNet. Are there any easy options (i.e., patch cables available) to convert the 9-pin D-sub from the PCI-8532 to DNet micro-style, or do I have to crimp my own connectors? I have come up empty so far...
Shane.
10-30-2014 09:27 AM
Shane,
I'm not too sure where you can find DeviceNet to DB9, as NI does not produce those types of cables. There are various DeviceNet to serial modules that require wiring. I suggest looking at Rockwell Automation products as they carry a lot of different cables for DeviceNet and you may find a DeviceNet to DB9 cable there.
Logan
Applications Engineering
