Industrial Communications
DF Profi II Set Slave Address.
What is the content of the telegram the DF PROFI II board sends when it is a master and the Set Slave Address is Sent from the configurator II software?  I am designing a slave with a settable address and can't get this function to work.  All I get a is "fault" in the Status. I've tried numerous combinations and am now leaning towards the DF Profi II isn't sending the correct telegram to SAP 55. I don't have a bus analyzer so I was hoping someone here might know.
Any Help with this would be appreciated.
Regards
John
(8,778 Views)
The DF Profi II firmware doesn't support the Set Slave Address command yet. Right now the only way to configure a new address for your slave is to reconfigure it to a new address by using the init function in LabVIEW. I don't know anything about a "set slave address" function within the Configurator II. What do you mean with that?
DirkW
(8,750 Views)
Hi Dirk
Thank you for your response.
The Set Slave address dialog is available in configurator II under the online menu selection. It is only available if the gsd has Set_Slave_Add_supp=1. I was hopoing someone has a bus analyzer and can tell me what the content of the telegram is that they see. It should be minimum of 4 bytes
byte 0  New Slave address
byte 1  Ident HI
byte 2  Ident Lo
byte 3  future change address not allowed.
If anyone has a bus analyzer and can tell me what they recieve on SAP 55 when they hit they try to set slave address it would help me out.
Regards.
(8,746 Views)
I have a DF Profi II board that I want to set as master and a I have two slave devices(D-MAX). I have with me the input -output mapping for the slave devices. I want to set the slaves using the Configurator II. Please send any information you have about the procedure to set the input-output map in the configuration. Suggestions are appreciated.
Thank you
(7,144 Views)
