Hi all,
I'm using DNP3 on a Linux RT IC-3173, I set my IC as an OutStation and want it to not use the time reference sent by the Master.
I struggled a bit to do that because the documentation (see here) is either outdated or only apply to other RT OSes.
- So on the IC I went to /usr/local/natinst/share/TimeSync
- I removed the "DNP3 1" element from "timeReferences" in the tsm.json file
- rebooted the IC
Then it works fine : when the DNP3 Master sends a Set Time request, my OutStation sends an acknowledge but doesn't use the timestamp sent by the Master.
It took me a lot of time to figure this out so I thought I'd share it here.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
