Industrial Communications
Datasocket -2147417843
Hi there,
I´m using a Siemens Profibus DP PC card to communicate with one slave on the Profibus.
Thi VI is working very well, but when I open another Sub-VI or another application on PC, I get this DataSocket error:
-2147417843
I really can´t find any problem or error, maybe someone can help me...!
(9,883 Views)
it's a known problem. I've sent an email to our developers.
regards,
Thomas Sandrisser
NI Germany
(9,881 Views)
Hi Thomas,
I found out, when the VI (the one which handels the OPC) is running and I click on the "Close Window cross (on the top right)" the error appears immediately. Maybe this helps.
If you need the source, please let me know.
(9,881 Views)
Hello
I'm needing information about comunication Siemens CP5611 Profibus PCI card and LabVIEW. The purpose is acquire data from  a CNC Simenens 810D via Profibus developing a data acquisition system in LabVIEW to do the communication to CP5611. If you have some information about the configuration of CP5611 with SIMATIC NET (OPC server) and additional information contact me.
Thank's
(9,447 Views)
