Industrial Communications
DeviceNet missing information
I am really stumped. I have a PCI 8532 connected to an Allen Bradley CompactBlock I/O 1791D-8B8P, 8 inputs, 8 output. Everythinng is running fine. I'm using the DeviceNet examples and I am communicating with the board. My only problem is that I have no idea how to translate anything and no idea what kind of messages to send it. I send some bits and it responds but have no way to translate it into useful data. I have been all over Google looking for documentation but can't seem to find what I need. So how can I get my vi to do things that makes sense on the I/O module?
PaulG.
Retired
(4,739 Views)
I never worked with Allan Bradley DeviceNet modules, but I used a lot of other DeviceNet devices. I suspect that this one doesn't support Explicit Messages at all. I found here some info:
additional:
You could try to establish Poll Mode connection (1 byte out / 1 byte in). The 1 byte Out should activate the outputs of the module, and respectively the 1 byte In hopefully reads back the input channels.
I an not very familiar with the Industrial Communication for DeviceNet. I still use the old NI-DNET VIs, even with the new cards. You probably need to find an EDS file for this module, or just use the EDS file for a similar module with 1 byte In / 1 byte Out if needed.
(4,726 Views)
