Industrial Communications
DeviceNet settings not shown in MAX
Hi all,
We have different ATE systems for EOL testing. These tester has DeviceNet card identical at same slot.
The DeviceNet drivers are installed with the NI Installer.
But unfortunately I couldn't see the settings page in NI MAX?
I can able to see them in other similar testers. At first I thought NI MAX would be corrupted, I reset the same and tried again but still no update.
Is there something i'm missing?
 Thanks in advance.
(3,117 Views)
To help us understand, can you post images showing:
What are you seeing?
What do you expect to see?
Attached is a picture of what I see in MAX after a successful DeviceNet install.
Andrew T.
"His job is to shed light, and not to master" - Robert Hunter
(3,085 Views)
Hi Andrew,
here's the image
Expected,
Actual
(3,074 Views)
