Industrial Communications
Eaton PLC Ethernet Communication with Labview
Does anyone have experience using Labview with Eaton PLC through Ethernet ? I am considering a environmental chamber which comes with this PLC. I can not find much information about labview support for it. Any suggestions would be greatly appreciated.
Regards
FLiu
(4,793 Views)
Hello FLiu,
Could you describe your Eaton PLC application, including:
What protocols does your PLC support? (EtherNet/IP, TCP/IP)
Which do you plan on using?
Will you be/are you using an OPC Server in your application?
Nadine H.
(4,768 Views)
