Industrial Communications
Error while Execution build
Hi
  I am using Profibus communication to drive a siemens servo drive. I have developed the code using Profibus master Vis using Comsoft Profibus Toolkit. Using code i can run my application perfectly. But when i convert into Exe its showing the device is not initilized error msg. I don't know how it happens and what is the solution for it. Plz replay me its urgent...........
Regards
karthik
(7,914 Views)
Dear Karthik,
it could be, that after starting the application via the exe-file, it doesn't find the "DFP2Image.bin". The exe-file and the "DFP2Image.bin" have to be located in the same directory.
You can find the file in "C:\program files\Comsoft GmbH\Profibus VISA Driver\Firmware\".
Sven
(7,904 Views)
