Industrial Communications
Ethernet/IP Implicit I/O Adapter to Productivity PLC Scanner
I am trying to talk to Productivity PLC using I/O Implicit Messaging with the Industrial Communication Ethernet/IP toolkit.
The LabVIEW is the adapter, the Productivity PLC is the scanner, and below are the configurations:
Instance - 100
  • Type - Producing(provides input to the Productivity PLC)
  • Size - 1 byte(8bit)
Instance - 101
  • Type - Consuming(Takes output from the productivity PLC)
Productivity PLC
Same configuration with 1 byte(8bit) being the size for both input/output.
The issue is I am getting 'Invalid Segment in path' error on the productivity PLC. It appears there isn't any issue with the TCP/IP end, since it shown as connected with adapterName and vendor ID read without issue.
Can anyone let me know if LabVIEW can perform general implicit I/O as an adapter to all PLC? I suspect the issue is on the LabVIEW end with how the CIP is formated, since I dont have any issue with implicit I/O using any other adapters.
Mao
Message 1 of 1
(1,884 Views)
