Industrial Communications
Ethernet communication to NU-EP1 laser sensor controller
I´m having the same or similar problem.
I have a DL-EP1(ethernet/ip) connected to an ig1000 laser sensor and the DL-EP1 connects directly to the Pc without a PLC .
I have installed the Ni Industrial communications for ethernet/ip 14.0. (Labview 1013 sp2)
The indicators in DL-EP1 display:
Link/activity indicator (LINK/ACT) green Blinking - Link correctly established, and exchanging data. – OK
Module status indicator (MS) Green solid - The NU-EP1 is operating  correctly. – OK
Sensor communication indicator (D-bus)- Green solid - Communicating correctly.
Network status indicator (NS) Green Blinking - Connection is not established. - Check that the NU-EP1 is registered in the scanner. – NOK
How can I connect to DL-EP1 correctly?
Could you please help me.
Best Regards,
Valter
Message 11 of 14
(4,118 Views)
Valter,
If I understand correctly, your setup looks like this: NU-EP1 -> DL-EP1 -> PC
Which LabVIEW functions are you using to communicate to the DL-EP1?
Daniel C.
Message 12 of 14
(4,091 Views)
Hi, I will be working with a very similar application.
Have you been able to communicate with the Keyence Ethernet/Ip device?
Do you have any suggestions?
Message 13 of 14
(1,823 Views)
Hi, I to have same problem any suggestion or sample program for Ethernet/IP
Happy to Wire
Message 14 of 14
(1,676 Views)
