Industrial Communications
Ethernet/ip- pepperl+Fuchs IO module
Hi all, I have a pepperl+fuchs I/O module (ICE1-8IOL-G60L-V1D) and i want to communicate it labview using ethernet/ip to monitor the inputs and control the outputs.
Do you know how can i do this?
(2,878 Views)
Hi, There are many examples in NI EtherNetIP which will help to communicate your module with labview. Is there any problem when connecting your module with labview?
(2,838 Views)
