Industrial Communications
How to convert a hexadecimal 1D array to Packed ASCII in HART Communication protocol with LabVIEW
I'm working on HART communication protocol with LabVIEW for my project. Here, I have to convert a hexadecimal 1D array to packed ascii to represent it as a readable format. I'm able to convert the hex 1D array to a string with Byte array to string function. But to convert it to Packed ASCII is where I got stuck. Attaching the VI for reference. The string I received after conversion is  ”PTÔ MMH7»(. But the Packed ASCII I need to get with the hex 1 D array is HARTTESTFRAMEALYST 7.2_
Message 1 of 9
(1,823 Views)
There is no VI attached.
Message 2 of 9
(1,819 Views)
Sorry again. Please ignore the previous attachment and check this one.
Message 4 of 9
(1,811 Views)
(Please do not maximize the diagram and front panel to the screen, nobody likes to stare at 95% whitespace).
The algorithm for "packed ASCII" is quite simple. What have you tried?
(There is also this discussion, but the code is horrible and does not give the right result)
Message 5 of 9
(1,763 Views)
Accepted by topic author velaravind07
I am sure you figured it out by now, but here's a simple implementation.
Message 6 of 9
(1,746 Views)
Typically, it is more efficient to operate bitwise (8x less memory compared to boolean arrays!), so here is one possibility. The result is the same:
Message 7 of 9
(1,704 Views)
Thanks everyone for the support. I'm now able to convert the hexadecimal 1D array to Packed ASCII
Message 8 of 9
(1,664 Views)
Just to be clear about the semantics. The input array is packed ASCII (as byte array) while the output is just a plain string,
The shown code does NOT convert to "packed ASCII" but goes the other way (unpacking!). Of course it would be equally simple to implement the reverse operation if needed.
Message 9 of 9
(1,554 Views)
