Industrial Communications
How to use PXI-8532 in LabVIEW Development Environment?
I want to know how to use PXI-8532 in LabVIEW Development Environment.
I'm using
1. Windows7 32bit
2. LabVIEW Pro 2012 SP1 32bit
3. NI-Industrial Communications for DeviceNet 2.3
4. PXIe-1062Q
5. PXIe-8135
6. PXI-8532 *2 (Names are "dnet0" and "dnet1".)
* Both PXI-8532 are installed in the same chassis (PXIe-1062Q).
I want to construct the system that "dnet0" sends data, and "dnet1" receives it. The data type I want to use is an array of bools.
I made VI (test.vi), but it does not work.
Could you tell me the reason why my VI doesn't work correctly.
Thank you so much for your help and time.
Best Regards,
volcanon2
Message 1 of 1
(6,100 Views)
