Industrial Communications
I have an error message (Not enough memory to complete this operation) when saving 6250000 data points
Dear all, I have an error message (Not enough memory to complete this operation) when saving 6250000 data points from an oscilloscope (YOKOGAWA) which is connected via USB. I am using a computer with core i5 processor, 6 MB cache memory, 4 GB ram. Thanks in advance.
(5,155 Views)
I'm not sure what you're trying to ask here.
It sounds like you don't have enough memory allocated for LabVIEW to store that many data points at once.
Try writing the data to a measurement file.
-CB
Casey B.
(5,116 Views)
Dear Eng. Casey B.
I followed the instructions in this link
http://zone.ni.com/reference/en-XX/help/371361J-01/lvhowto/enable_lrg_ad_aware/
to increase the allocated memory.
I am already use a measurement file to save the data.
In my labview code I am using a mathscript code to process the signal.
Thanks in advance for your help,
Haitham.
(5,090 Views)
