Industrial Communications
IEC61850 GOOSE Getting Started: error 36115
Hi All,
I need to implement an IEC61850 GOOSE server and am trying to get the examples to run on my PC. I have LabVIEW 2015 and the toolkit installed and am trying to run it as a Windows VI (so not RT).
There is an example project that is included with the toolkit, but I have not had any success running anything.
I have tried to run the "Publisher.vi" but always get error -36115 which is "Failed to find adapters". I have set the Adapter MAC Address to the correct value for my ethernet adaptor on my PC.
Attached is a screenshot of the code that is failing, the only input I can control is the MAC address and I have copied this directly from the "ipconfig /all" output.
Any other ideas?
(4,135 Views)
Hello! I have a similar error on Windows 10. When using Labview 15 with Windows 7 everything works
(1,631 Views)
