Industrial Communications
Is it possible to find and set the IP address for EtherCAT slaves
The EtherCAT Master is cRIO-9049 and slaves are Yaskawa EtherCAT Servopack.
(4,992 Views)
Do you mean use Ethernet over EtherCAT?
(4,977 Views)
Yes!
(4,973 Views)
I can confirm you that NI EtherCAT doesn't EoE. Can you tell me the use case why you need to set IP address for EtherCAT slaves?
(4,970 Views)
I want to control Yaskawa motors with cRIO-9049. I need to clear one alarm which means I must use SigmaWin+. To build connection between Servopack and SigmaWin+, I need to know the IPV4 address of the slave.
(4,965 Views)
Hmm, does the driver support clearing the error via EtherCAT? If not, I'm am afraid you need to get the IPV4 address in other ways. I am not familiar with Yaskawa motors. But I know there is an Ethernet port on some AKD drivers, people can auto-scan the IPV4 address by using AKD WorkBench software.
(4,962 Views)
