Industrial Communications
Is there a C or CPP interface manuals for NI EthernetIP Driver?
I would like to program EthernetIP communication from a Visual C++ application for Windows or from WindRiver Workbench application for cRIO/sbRIO.
I planned to use NI EthernetIP driver for this task. There is no help information about C interface for NI EthernetIP driver in LabView Help System.
And then I try to generate C Code (for code examples of using C interface) from "LabView CCodeGenerator" it's need the Password for "EthernetIP Set Assembly Instance Data.vi" for successful generation.
How to interact with NI Ethernet IP driver from C, CPP code?
(5,922 Views)
Hi yuri,
There is no c-support as the entire toolkit is coded in LabVIEW. However, rather than use the c-code generator to generate code you can create a wrapper for the library with a dll. This approach should allow you to use Visual C++ as long as the LabVIEW run-time engine is also installed.
I can't think of a way you will be able to get Vxworks c-support.
Jesse Dennis
Engineer
INTP
(5,917 Views)
