Industrial Communications
Is there any method to change adapter mode of eth0 to EtherCAT?
Hi!
I'm using sbrio 9651 with customized carrier board.
I have to use EtherCAT for my project, but unfortunately my carrier board does not have eth1 port.
All the documents say that adapter mode of eth1 should be EtherCAT.
Even trying to make new carrier board, Ethernet PHY chip KSZ9031MNXIA, which is the only supported PHY for secondary ethernet of sbrio 9651,  is out of stock.
So I wonder whether there is any trick to change adapter mode of eth0 to EtherCAT?
Can someone help me?
Message 1 of 1
(1,411 Views)
