Industrial Communications
Kollmorgen EtherCAT Drive Flexible PDOs mapping
Is there an easy way or any ways to support Kollmorgen AKD EtherCAT drive Flexible PDOs mapping with LabVIEW?
What is LabVIEW doing with a fix PDO mapping that makes the drive aware of the PDOs it should use? Will it try to do the same for PDOs marked with "fixed=0" ?
Danny
(1,934 Views)
Did you end up controlling the AKD Drive without softmotion using the EtherCAT tag in the LabVIEW project? which EtherCAT XML did you use?
Thank you!
Patrick
(1,503 Views)
