Industrial Communications
Looking for NI Industrial communications for DeviceNET 2.3.0 examples in LV 2014
It does not look like the DeviceNet examples are being installed in LV 2014 (in this case those for NI INdustrial communications for DeviceNET 2.3.0).  Is this intentional or perhaps I did not install something correctly?
Message 1 of 11
(7,358 Views)
Unfortunately, NI Industrial Communications for DeviceNET 2.3.0 supports up to LabVIEW 2013, so it will not add support (thus, examples) for LabVIEW 2014. You can verify that information in the driver's Readme file.
There have not been any new releases so far so if you need to work with it, you will have to downgrade to LabVIEW 2013 (you can download it here).
Camilo V.
Message 2 of 11
(7,320 Views)
Hi all,
I just wanted to add to this.  Currently, we have not released DeviceNet support for LabVIEW 2014.  However, 2014 support is coming.  The current recommendation is to use LabVIEW 2013 SP1 with the DeviceNet 2.3 driver until the new driver releases.  We apologize for this inconvenience.
Thanks!
Matt S.
Industrial Communications Product Support Engineer
Message 3 of 11
(7,172 Views)
How soon can we expect the lv 2014 support?
thanks,
Joe
Message 4 of 11
(6,665 Views)
I need to know if the new version of NI-Industrial Communications for DeviceNet to support LV2014 is released or not yet ?
Many Thanks,
Best Regards,
Message 5 of 11
(6,658 Views)
Unfortunately, there's not an NI-Industrial Communications for DeviceNet supported in LabVIEW 2014. For now the workaround is still using LabVIEW 2013 SP1 with version 2.3 from the driver as pointed by Matt.
Camilo V.
Message 6 of 11
(6,640 Views)
It looks like the LV2014 sp1 just released last week, but I didn't see anything about the DeviceNet update.
Does that mean the DeviceNET support is dropped for LV 2014 and onward?
Joe
Message 7 of 11
(6,635 Views)
Hi Joe,
Support for DeviceNet has not been dropped.
We are currently working on releasing NI-Industrial Communications for DeviceNet 14.5.  It should be available later this month or earlier next month.
Matt S.
Message 8 of 11
(6,631 Views)
Thanks for the clarification, Matt.  Our code support DeviceNet as one of the communication protocols.  Even though it is not used not much but still need to have it.
Joe
Message 9 of 11
(6,626 Views)
Hi Joe,
I wanted to let you know the DeviceNet 14.5 has been released.  You may download it here: http://www.ni.com/download/ni-industrial-communications-for-devicenet-14.5/5237/en/
Matt S.
Message 10 of 11
(6,580 Views)
