Industrial Communications
MODBUS TCP communication with diff node IDs
I'm working on win ce 6 modbus tcp client server, application is developed for a client server communication and it is working fine. now req is my slave device should respond to the diff slave addresses polled by master/client. Can I just change slave id and establish connection or I need to close previous connection and again establish new one below is the code, which is working fine for one node, if I polled with other node ID then it gives exception. what change it req to communicate with other node simultaneously. My device should be able to communicate with 32 diff nodes on modbus tcp. Shall I create individual threads for each node but how they will communicate on same port? before establishing connection with other node shall I close previous node?
serverLoop()
   int iReturnCode = (FTALK_SUCCESS);
   int result;
   int sockIdx;
   int recvResult;
   int sendResult;
   fd_set fdSet;
   timeval timeVal;
   SOCKET maxFileDes;
   int replyCnt;
   int tcpOption;
   if (!isStarted())
      return (FTALK_ILLEGAL_STATE_ERROR);
   // Prepare file descriptor set for select call
   FD_ZERO (&fdSet);
#ifdef _MSC_VER
#  pragma warning(push)
#  pragma warning(disable: 4127)
#endif
   FD_SET (listenSocket, &fdSet);
#ifdef _MSC_VER
#  pragma warning(pop)
#endif
   maxFileDes = listenSocket;
   for (sockIdx = 0; sockIdx < MAX_CONNECTIONS; sockIdx++)
      if (connectionSocketArr[sockIdx] != INVALID_SOCKET)
#ifdef _MSC_VER
#endif
         FD_SET (connectionSocketArr[sockIdx], &fdSet);
#ifdef _MSC_VER
#endif
      if (connectionSocketArr[sockIdx] > maxFileDes)
         maxFileDes = connectionSocketArr[sockIdx];
   // Block until accept request or received data or time-out
   timeVal.tv_sec = (long) timeOut / 1000L;
   timeVal.tv_usec = ((long) timeOut % 1000L) * 1000L;
   if (timeOut == 0)
      result = select((int) maxFileDes + 1, &fdSet, NULL, NULL, NULL);
   else
      result = select((int) maxFileDes + 1, &fdSet, NULL, NULL, &timeVal);
   if (result == SOCKET_ERROR)
      return (FTALK_FILEDES_EXCEEDED);
   // Check for time-out
   if (result == 0)
      TRACELOG1("Slave poll time-out!\n");
      dataTablePtr->timeOutHandler();
      iReturnCode = (FTALK_REPLY_TIMEOUT_ERROR);
   // Connection accept request
   if (FD_ISSET (listenSocket, &fdSet))
      // Search a free socket
         if (connectionSocketArr[sockIdx] == INVALID_SOCKET)
            struct sockaddr_in peerAddr;
            SOCK_LEN_TYPE peerAddrLen = sizeof(peerAddr);
            // Yes, socket is free, try to accept a connection on it
            connectionSocketArr[sockIdx] = accept(listenSocket,
                                                  (struct sockaddr *) &peerAddr,
                                                  &peerAddrLen);
               // Check id connection shall be accepted
               if (!dataTablePtr->validateMasterIpAddr(inet_ntoa(peerAddr.sin_addr)))
                  shutdown(connectionSocketArr[sockIdx], SD_BOTH);
                  closesocket(connectionSocketArr[sockIdx]);
                  connectionSocketArr[sockIdx] = INVALID_SOCKET;
                  TRACELOG2("Connection rejected on slot %d\n", sockIdx);
               // Set socket options (we ignore errors here, not critical)
#ifdef TCP_NODELAY
               tcpOption = 1; // Enable option
               setsockopt(connectionSocketArr[sockIdx],
                          IPPROTO_TCP, TCP_NODELAY,
                          (char *) &tcpOption, sizeof (tcpOption));
#endif
#ifdef SO_SNDBUF
               tcpOption = MAX_MSG_SIZE;
                          SOL_SOCKET, SO_SNDBUF,
#endif
#ifdef SO_RCVBUF
                          SOL_SOCKET, SO_RCVBUF,
#endif
#ifdef SO_LINGER
               tcpOption = 0; // Disable option = discard unsent data when closing
                          SOL_SOCKET, SO_LINGER,
#endif
               TRACELOG2("Connection accepted on slot %d\n", sockIdx);
            break; // Leave for loop
   // Data received on socket
         if (FD_ISSET (connectionSocketArr[sockIdx], &fdSet))
            recvResult = recv (connectionSocketArr[sockIdx],
                               (char *) bufferArr, sizeof (bufferArr), 0);
            sendResult = 0;
            replyCnt = 0;
            // Process client message
            if (recvResult >= PREFIX_LEN) // Process only minimum message sizes
               short dataLen;
               dataLen = (short) ((bufferArr[4] << 8) | (bufferArr[5] & 0xFF));
               // Validate length before processing message
               if ((dataLen + PREFIX_LEN) == recvResult)
                  replyCnt = processMessage(&bufferArr[PREFIX_LEN],
                                            recvResult - PREFIX_LEN);
                  // The first two bytes (msg id) are returned untouched
                  bufferArr[2] = 0; // protocol identifier
                  bufferArr[3] = 0; // protocol identifier
                  bufferArr[4] = (char) ((replyCnt) >> 8);
                  bufferArr[5] = (char) ((replyCnt) & 0xFF);
                  sendResult = send(connectionSocketArr[sockIdx],
                                    (char *) bufferArr,
                                    replyCnt + PREFIX_LEN, 0);
            // Check for disconnection and errors
            if ((recvResult < PREFIX_LEN) ||
                (sendResult != replyCnt + PREFIX_LEN))
               // Free socket
               if (recvResult == 0)
                  TRACELOG2("Disconnected slot %d nicely by other peer.\n",
                            sockIdx);
               else
                  TRACELOG2("Forced disconnection on slot %d!\n", sockIdx);
   return iReturnCode;
Message 1 of 1
(5,833 Views)
