Industrial Communications
MXOPC IO items
Setup:
NI LV2014 with DSC module, Mitsubishi MXOPC, Mitsubishi FX3UC PLC. we are using Mitsubishi MXOPC servers to connect to the I/O of Mitsubishi PLC over OPC interface. I use local shared variables to bind them with the IO items. During normal R/W cycle, I read the shared variable or write to it.
Issue:
I am trying to initialize IO items of a OPC IO Server programmatically so that I can bind shared variables to each of them.
as a workaround, what we have been doing is manually initialize IO items by opening the tree items (as seen in the Image). There are IO items located in all_IO. so once I open the tree item, all works OK.
So far what have I tried is to use Create and Configure IO server Express VI. Unfortunately, this VI is not doing a great job for me as it does not initialize the IO items located inside the IO server.
(4,726 Views)
Hello All,
Is there anyone who had similar issue?
Please help.
regards,
DB
(4,680 Views)
