Industrial Communications
Modbus Serial Comm
I am new with LabView so I need some general/basic guidance.
I have a serial Modbus based project.  The project needs to repeatedly make 3 calls each getting 64 registers which then need to be processed (read only for right now).  I need to update ~every 3 seconds or so.  I am using the MB Serial Master Query.  I am getting timeout errors which I want to minimize/manage.  Here are my questions:
1.  I am using a timed loop with three sub-diagrams.  Is this the best way?
2.  Is there a way to know when one of the calls ends (to control time in between calls)?
Thank you for your help.
(6,215 Views)
Before you can use ModBus you have to be sure that your hardware layer is OK.
What interface are you using. Do you know it is OK ?
Does your ModBus device supports the ModBus Loopback command ?
Kees
(6,207 Views)
KC,
Thank you for the reply.  The hardware is a gas analyzer that we are developing.
I probably should have clarified some things.  I can get the Modbus communication to work.  It might work for 2 minutes and then time out.  It might work for an hour and time out.  So hardware is good, setup of registers, comm parameters are good, etc.
I have use a third part software (Modscan) to test the Modbus setup and have had no issues with this.
I am wondering if there needs to be delays in-between each of the read commands?  If so, do I do it in the loop?  What parameters control the delay between read commands?  Is there a way to get know when one command is done so I can initiate the next command?
(6,195 Views)
Ok, post your vi here.  I will have a look at it.
Kees
(6,191 Views)
