Industrial Communications
Modbus TCP max registers..
I am using the NI Modbus Library 1.2.1.  I have successfully implemented it with another controller that doesn't have the 125 register limitation, but I am finding that my writing/reading the registers seems to force stop at 125.  Is this changeable in the library?   If not, what is the best work around?  Multiple reads? Multiple Servers (Slaves)?
(9,201 Views)
Hey wegunterjrNGC,
Unfortunately, the 125 limit is a hard limit of the protocol and to reference registers higher than this amount you will have to perform multiple reads, as you mentioned.
Ryan
Ryan P.
CLA
(9,188 Views)
Okay.  That makes sense.   I will just have to read twice (ie, once for the first 125 using Read Holding Registers with a 1 starting constant and 125 read constant, and the second time starting at 126 starting constant and some number less than 251, right)?
(9,179 Views)
I believe you usually specify a start constant followed by the number of registers to read. So, it would be something like:
1. Start = 1, Read/Length = 125
2. Start = 126, Read/Length = 125
That should read registers 1-250. However, if your code is set up to set a start and end register then the way you described would work fine.
Ryan P.
CLA
(9,169 Views)
