Industrial Communications
Modbus communication with Panasonic MINAS A6 servo drives
Dear All,
I need some help in controlling panasonic MINAS-A6  Servo drive model drive with Modbus control from LabVIEW. Has any one did this kind of application before. ?
Message 1 of 12
(16,332 Views)
hi have you met solution for the post
Message 2 of 12
(15,509 Views)
Hi there, I've done the application to control the MINAS-A6 servo driver before.
First, you need to define what communication you want to use, either RS232 or RS485. Then you will need to refer the full user manual to wire the X2 connector to be connected to the servo driver, based on RS232 or RS485 configuration. For my case, I've used the RS485 since I want to control 4 servo motor in a program simultaneously.
Referring to MINAS-A6 Modbus manual, you'll need to configure the servo driver parameters to enable the Modbus RS232/RS485 using Panaterm software through USB communication.
Then you'll need to set up the block operation of the servo driver so that your LabVIEW could control the servo by executing the block operation based on the address listed in the Modbus manual.
Finally, when everything is ready, you can start off writing your simple VI to try communicate with the servo driver.
I've included the test VI and MINAS-A6 Modbus manual for your further reference.
Hope this will help you, good luck.
Message 3 of 12
(15,229 Views)
Hello yazidroslan,
I need your help in controlling MINAS-A6 servo driver using RS-485/RS232 Communication,Please respond on here.
Message 4 of 12
(13,537 Views)
Hi Dilip1441,
Have you followed the instructions given from my previous post?
Message 5 of 12
(13,528 Views)
Dear sir,
Actually I don't know how to communicate with MINAS-A6 using Modbus, I want to control MINAS-A6 Servo using Ethernet to Modbus converter module,Please tell me Which commands i need to give from the PC and the order of the commands,Please support on this Thank you.
Message 6 of 12
(13,524 Views)
Can anyone convert this VI to LV 2016 for me?
Message 7 of 12
(12,762 Views)
Can anyone convert this VI to LV 2016 or lower version for me?
Message 8 of 12
(12,754 Views)
Here you go, kindly find attached .vi
Message 9 of 12
(12,701 Views)
Thank you👍
Message 10 of 12
(12,696 Views)
