Industrial Communications
NI-DNET or NI-CAN driver using USB-8473 to get a Devicenet communication
Hi.
I have a doubt regarding the proper driver to get a link between a Beckhoff BK5220 header and Labview, using USB-8473 interface.
For this purpose, we are currently using a PCMCIA-CAN/2 card with NI-DNET1.41 driver and Labview 7.0, but our new laptops has been delivered without PCMCIA slot, so I have to find al alternative solution.
I found the USB-8473 interface in NI Web. To operate with it We have to upgrade our Labview (it is not a problem) and upgrade at the same time the driver, but in the last version of NI-DNET driver, this hardware is still not supported.
In the README of the last version of NI-CAN driver, it is supported, so, knowing that Devicenet protocol is actually a Can field bus protocol, and that we are currently using succesfully  a generic CAN PCMCIA card for this purpose,my question is:
Could We use this hardware with this NI-CAN driver to get a link with a Beckhoff BK5220 using Devicenet protocol?
Please let me know how I can solve it.
Thanks in advance
Best Regards
Raul Gracia
(6,987 Views)
Hi Raul,
     You may find this KnowledgeBase interesting. Moreover, the following KB says "the user can implement DNET specifications using the NI-CAN Frame API". I encourage you to give a call to a National Instruments Internal Sales Engineer so that he can give you a hand with your hardware configuration .
David Oña
(6,978 Views)
