Industrial Communications
NI EtherCAT driver for NILRT (niecati210k)
Hi, (sorry I also posted in NI Linux RT discussion)
Still in the process to find alternatives to the discontinued Industrial Controllers ...
I try to install the ni-ethercat-driver-dkms on a custom NILRT (distribution, github) with a hardware that have intel i211 chipset. When I change the ethernet adaptor mode to "EtherCAT" in NI MAX, the ethernet adapter disappear from Linux and NI MAX. I think it's when it try to load the niecat210k driver (init.d/iecatdriver)
Does this NI driver only compatible with Intel I210 chipset? Lots of little new mini PC come with I211 chipset.
Anyone able modify the niecati210.c to accept other ethernet device like the i211 ?
Thank you.
Patrick
Message 1 of 1
(1,449 Views)
